Where is the rest of the JRE for the Linux clients on DCO 7.5.0?
  • EcoStruxure IT forum
  • Where is the rest of the JRE for the Linux clients on DCO 7.5.0?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 12:50 PM . Last Modified: ‎2024-04-09 11:42 PM
637
The contents of the jre directory for the 7.5.0 DCO client are, for the most part, missing.
'/jre/bin/java' is all that is in there.  No libraries, etc.
(CID:96765201)
  • Data Center Operation
637
Hi Tim,
Log files (which was initially requested) not needed, thanks - the issue could be reproduced for debian upgrade and linux clients.
Here is a simple work around:
ssh log in to the server, and run
sudo su
Platform.pm post-configure
(CID:96765250)
Replies 5
638
Hi Tim,
sudo su
(CID:96765250)
Posted: ‎2020-07-02 12:51 PM . Last Modified: ‎2024-04-09 11:42 PM
That did it, thanks!
(CID:96765296)
Many thanks for sharing that it worked for you, great!
(CID:96765312)
The below command should be sufficient. sudo Platform.pm repack-clients
(CID:102924458)
Posted: ‎2020-07-02 12:51 PM . Last Modified: ‎2023-10-31 11:44 PM
