Posted: 2020-07-05 04:52 PM . Last Modified: 2024-04-03 04:21 AM
I am receiving the following server error when trying to update genomes in the DCO but I can't seem to find any information as to what is causing the problem. The error is "The server encountered errors. Consult the logs for more details."
(CID:139692455)
Posted: 2020-07-05 04:52 PM . Last Modified: 2024-04-03 04:20 AM
Hi Krista,
If you are running an earlier version of DCO 8.x (maybe 8.2.0), then I would suggest upgrading the product to latest release (currently DCO 8.2.12). Latest release contains the genome updates as well.
To answer you question, the client application.log file (usually located in C:\Users\
Kind regards
(CID:139692747)
I can't update to a later version as the Clustered servers are not supported. Eventually we will be able to upgrade and move to the disaster recovery node installation but not at this time.
(CID:139694313)
Posted: 2020-07-05 04:52 PM . Last Modified: 2023-10-22 04:18 AM
