Posted: 2020-07-03 06:31 AM . Last Modified: 2024-04-08 10:46 PM
Hi All ,
I tried to discover one server for server access , then the on/off seems disable in the menu bar . please
see attactment .
Just wanna check this concern , does this on/off function must be support Intel victual gateway ?
If so , then DCO will indentify these servers automatically , right ?
Best Regards
(CID:108827061)
You are correct. The on/off functionality depends on the Intel Virtual Gateway. So only if the server is discovered through IPMI and supports the functionality it will be possible to enable.
(CID:108827157)
Hi Kresten , Understood ,thank you for kindly reply . Best Regards
(CID:108827161)
Posted: 2020-07-03 06:32 AM . Last Modified: 2023-10-22 04:18 AM
