VMware vCenter integration in DCO - ESXi host drop error
  • VMware vCenter integration in DCO - ESXi host drop error
129
72
Posted: ‎2020-07-03 05:02 AM . Last Modified: ‎2024-04-08 11:28 PM
676
DCO integrated with VMware vCenter. It receives information properly but all ESXi hosts drop the following error in the event logs:
Name: Set host custom value Status: A specified parameter was not correct: key
I just would like to know why this error message generated and what is that DCO wanted to setup on ESXi?
VMware ESXi 6.0.0 run on hosts and sevice account has read only access which connect to vCenter.
(CID:106892535)
  • Data Center Operation
Posted: ‎2020-07-03 05:03 AM . Last Modified: ‎2024-04-08 11:28 PM
When the hosts are associated in DCO a custom property is set through vCenter about the location of the host.
You can see a list of the operations that are called from DCO here: Configuring VMware vCenter integration
(CID:106892550)
Posted: ‎2020-07-03 05:03 AM . Last Modified: ‎2023-10-31 11:41 PM
