Used and available U-positions in rack: ETL export?
  • Used and available U-positions in rack: ETL export?
129
72
Posted: ‎2020-07-03 04:00 PM . Last Modified: ‎2024-04-08 12:46 AM
729
In the rack properties, we have the available U-positions, and if we enable the Physical layer in the floor view, we can also see the used U-positions.
Are those values available in the staging database? We would like to send this information to ServiceNow.
Thanks in advance,
Christian
(CID:118003370)
  • Data Center Operation
Hi Christian,
I did a quick test, it seems yes, the etl export contains those information. The etl export table/swo_kpi lists the information for "USED_USPACE" and "TOTAL_USPACE".
Kind regards
(CID:118003392)
Hi Christian,
Kind regards
(CID:118003392)
Posted: ‎2020-07-03 04:00 PM . Last Modified: ‎2023-10-22 04:13 AM
