Upgrading DCO is not possible using Webmin?
  • Upgrading DCO is not possible using Webmin?
129
72
Posted: ‎2020-07-02 06:58 AM . Last Modified: ‎2024-04-10 01:49 AM
856
When using Internet Explorer and trying to upgrade the DCO server from the Webmin/Server configuration interface the pop-up boxes show an error message?
(CID:82640985)
  • Data Center Operation
Posted: ‎2020-07-02 06:59 AM . Last Modified: ‎2024-04-10 01:49 AM
This is a known issue in webmin 1.690 the issue has been reported in http://ehc.ac/p/webadmin/bugs/4427/?limit=25
Either you should use some other browser that does not have this limitation, or downgrade to 1.680.
(CID:89063818)
Good morning. What version are you upgrading from and to? What version of IE are you using?
(CID:83656768)
(CID:89063818)
Posted: ‎2020-07-02 06:59 AM . Last Modified: ‎2023-10-31 11:41 PM
