Upgrading DCE and DCO
  • EcoStruxure IT forum
  • Upgrading DCE and DCO
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 02:11 PM . Last Modified: ‎2024-04-08 01:23 AM
968
Is there any documentation on the Upgrade procedure for DCE and DCO servers?
Any recommendation?
I have not found any mention on software upgrade of DCE or DCO in their manual and guide PDFs.
thanks
(CID:114234165)
  • Data Center Operation
Posted: ‎2020-07-03 02:12 PM . Last Modified: ‎2024-04-08 01:23 AM
969
Hi Ivan,
For either of these, you'll want to directly contact your local tech support.
For DCO, you can find upgrade instructions on the EcoStruxure IT Help Center page such as this one:
Installation and Upgrade Guide
For DCE, It's simply downloading and clicking the "updates" menu and "apply server updates". The difference here as that with DCE you must do incremental updates. All of this info will be provided if yuo contact support. Additionally, you will be required to have software support to get the upgrade.
Steve.
(CID:114234173)
Replies 4
970
Hi Ivan,
Steve.
(CID:114234173)
Hi Ivan,
Instructions for updating DCE are always in the release notes. This is the latest version: StruxureWare Data Center Expert v7.5.0 Release Notes.
Release notes for older DCE versions are in the PDF Library.
Best,
Jackie
(CID:114234214)
Thanks Jackie!!
(CID:114234225)
Posted: ‎2020-07-03 02:12 PM . Last Modified: ‎2023-10-22 04:13 AM
