Posted: 2020-07-02 12:22 PM . Last Modified: 2024-04-09 11:52 PM
I get the error :
Upgrade failed : Upgrade directory not specified. Please update the module configuration!
When I attempt to update the server from 7.3.0 to 7.3.5. Has anyone seen this issue before?
(CID:96044797)
Hi Jason,
It seems you need to specify the "Upgrade directory", it can be done via Webmin -> StruxureWare DC Operation -> Backup,
and then under the "Backup settings" specify the Upgrade directory.
We have had several releases since 7.3.5, so it is not recommended to upgrade to an already out-dated version. I would suggest to upgrade the product to the latest version (currently DCO 7.4.5), which contains many enhancements and supports upgrading from 7.3 as well. Details and guide is available on the following page:
Upgrading to StruxureWare Data Center Operation 7.4.5
Kind regards
(CID:96044848)
Could you provide me a link to the latest code line 7.4.5? I was not given one. I updated the directory as you showed, but I am still getting the same error...... Any other ideas? Thank you for your help,
(CID:96044982)
I believe the local tech support would be able to provide the latest product installations for customers holding a valid support contract. Following website contains the contact details: http://www.apc.com/site/support/index.cfm/contact-information/ If the upgrade failure is limited to not specified upgrade directory, then I would suggest to make sure that the upgrade directory (default /data/upgrade) and the installation file is local to the server (and not on a shared network drive).
(CID:96763927)
Posted: 2020-07-02 12:23 PM . Last Modified: 2023-10-31 11:40 PM
