Posted: 2020-07-05 05:26 PM . Last Modified: 2024-04-03 03:21 AM
Hello
According the documentation there are 2 way of the upgrade DCO .
My customer has problem with create a new server for upgrade on secondary way .
How I can install a new version of the DCO to exists server (That install on RedHat) ?
Should I remove previous version (how I can do it ?) or I can run a new installation on exists ?
(CID:140707613)
Posted: 2020-07-05 05:27 PM . Last Modified: 2024-04-03 03:21 AM
Hello Boris
You are right, currently there are only two ways of upgrading DCO and those are from Webmin and installing new server and restoring database. Guide on how to install DCO on Red Hat can be found here (Installing DCO on Red Hat Enterprise Linux 7). Currently remove of DCO or installing on an existing installed version is not supported. We highly recommend using new install of Redhat and DCO.
Elvedin
(CID:140708681)
Hello any body .
Who can help me ?
(CID:140708582)
Hello Boris
Elvedin
(CID:140708681)
Posted: 2020-07-05 05:27 PM . Last Modified: 2023-10-22 04:12 AM
