Posted: 2020-07-04 02:48 AM . Last Modified: 2024-04-05 03:42 AM
I need to upgrade my DCO from 8.0.4 to 8.2. Upgrade instructions say to post a question if I d not have access to internet and have to install RPMs separately and someone will contact me.
(CID:126879571)
Hello Krista.
Do you have the DCO 8.2 ISO already?
If you do not, you should contact your local support team to get the link to the iso.
If yes, and your DCO server does not have internet access then you can use the upgrade procedure noted on this page: Getting from previous versions to DCO 8.x . I would recommend uploading the DCO 8.2 iso to the DCO server into a temp folder, then from the upgrade screen in webmin make sure you check the "do not download packages from the internet" as noted in the below screenshot.
This option will perform the upgrade and use the upgraded packages on included already on the iso. It will avoid trying to use the internet to get the latest package versions.
Regards
Greg Sterling
(CID:126879866)
Posted: 2020-07-04 02:49 AM . Last Modified: 2024-04-05 03:42 AM
Thanks so much for your help! Once I uploaded the file directly to the DCO serve instead of mapping to where it was on my desktop it worked!
(CID:126879871)
Posted: 2020-07-04 02:49 AM . Last Modified: 2023-10-22 04:12 AM
