Posted: 2020-07-05 08:16 PM . Last Modified: 2024-04-03 01:16 AM
Hi team,
is it possible to upgrade from DCE 7.2.1 to DCE 7.6.0 in a hardware appliance version?
Best regards
(CID:146276483)
Dear Javier,
Yes, it is possible to upgrade the DCE server or appliance version 7.2.1 to 7.6.0.
DCE upgrade needs to be done in the following order:
7.2.1-->7.2.2-->7.2.4-->7.2.5-->7.2.6-->7.2.7–>7.3.1–>7.4.3->7.5->7.6 -> 7.7.0
Please refer this k-base here to know the upgrade process.
Please contact your country SE technical support to receive the upgrade links. Your DCE must be under software support contract for the team to provide the upgrade links.
You can find the technical support contact here by choosing your country.
Bala
(CID:146276492)
Dear Javier,
Bala
(CID:146276492)
Hi Javier,
Yes, it is possible to upgrade the hardware appliance to latest version. Please notice that this will be a sequential upgrade so you will need to apply the upgrades in the following order:
You can watch the upgrade progress from the server web page. Once the upgrade completes, download and install client, login, make a backup, and start the next upgrade.
Kind regards
(CID:146276497)
Thank you for your quick support.
(CID:146276509)
Posted: 2020-07-05 08:17 PM . Last Modified: 2023-10-22 04:12 AM
