Unknown Estimated load values
  • Unknown Estimated load values
129
72
Posted: ‎2020-07-05 10:08 PM . Last Modified: ‎2024-04-03 12:34 AM
851
Hi! I'm having estimated load values in measured PDUs even when the adjusted nameplate values were set to 0. Yesterday while working on this, the values were correct (no estimated values in measured PDUs), but today when I opened DCO, I found this issue.
I'd appreciate some elightenment.
(CID:148769482)
  • Data Center Operation
Replies 5
851
Hello Javier.
One quick question. In the tools menu, preferences, how is the "power capacity" item set in your DCO installation? Is it set to "predictive power" like below?
If yes, then the estimated load in racks with measured power will be based on the measured power values, not the derated nameplate values in the assets themselves.
If is set to adjusted nameplate, then we have to look elsewhere.
Regards
Greg Sterling
(CID:148769797)
It is set in "Predicted Power"
Question: With this option, in racks where there is no posibillity of measurment, the load is taken from the adjusted nameplate too?
(CID:148769800)
Yes/Correct. If a rack does not have measurements, then the estimated load will be based on the standard nameplate or derated nameplate.
Regards
Greg Sterling
(CID:148769805)
Thank you very much. It worked!
Kind regards
(CID:148769803)
Posted: ‎2020-07-05 10:08 PM . Last Modified: ‎2023-10-22 04:10 AM
