Uniflair ARAC1084
  • EcoStruxure IT forum
  • Uniflair ARAC1084
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:41 AM . Last Modified: ‎2024-04-08 11:16 PM
1024
Uniflair ARAC1084
How can i take monitoring of ARAC1084 on laptop to check unit status and want to know about end of life cycles of its parts and compressors.
(CID:108235526)
  • DCIM Support
Posted: ‎2020-07-03 05:41 AM . Last Modified: ‎2024-04-08 11:15 PM
1025
Muhammad,
You would need to post on forums.apc.com, or contact your local technical support, to find out about end-of-life cycles of its parts and compressors.
Is the Uniflair already being monitored by StruxureWare Data Center Expert?  If it is, you should be able to view information within StruxureWare DCE on the unit by viewing its alarm history and device sensors.
If the Uniflair has a web interface, you should be able to access the device to view alarms and status from there.
Cory
(CID:108824562)
Replies 6
Hi shahzad.engr123, thanks for posting. Lets see who can be of assistance here. @community any ideas? Kind regards Ditte
(CID:108824324)
Hi Ditte... I think Cory McDonald can be assistance here.
(CID:108824348)
Need your kind support for Uniflair ARAC1084 configuration with Struxureware sentral.
(CID:108824393)
1026
Muhammad,
Cory
(CID:108824562)
Thanks cory
(CID:108824620)
Posted: ‎2020-07-03 05:41 AM . Last Modified: ‎2023-10-31 11:40 PM
