Posted: 2020-07-04 07:36 PM . Last Modified: 2024-04-04 11:10 PM
I've encountered this error when upgrading 7.3.1 -> 7.4.3. I started the upgrade and the server has been at this screen for about 2 hours. Before this, I added an additional drive as outlined in the FAQ article. I have a snapshot of the machine on 7.3.1 that I can roll back to if need be.
(CID:132657808)
Dear Jeremiah Shaver,
Tell us, please, could you solve your problem or not?
With respect.
(CID:132662558)
Yes, I did. Ended up running a backup from within DCE, re-installing the server from new, and restoring from backup. Was able to successfully upgrade after that.
Another admin must have changed the size of the root drive.
(CID:132662809)
Thanks for the clarification: i.e., your problem as well as many similar ones was due to lack of free space on the DCE-server storage (see for example topics Physical DCE AP9470 to VM and ).
With respect.
(CID:132662851)
Posted: 2020-07-04 07:36 PM . Last Modified: 2023-10-22 04:10 AM
