Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-04 03:30 PM . Last Modified: 2024-04-05 12:32 AM
Hello Jef Faridi
After the update I'm unable to open the above rooms, the one highlighted in circle for the same area i can open the rest of the rooms only these two rooms are showing some error (the screen-shot is attached) the client gets restart
We are actually using this staging area for work order purpose
Kindly suggest
PS: if you need any additional details like logs or any info i can provide you that also
Thanks and kind regards
(CID:129409602)
Posted: 2020-07-04 03:31 PM . Last Modified: 2024-04-05 12:32 AM
Hi Waseem,
May I ask for the copy of the latest backup file, then we will looking into that right away - I will send you an invite from my =S= box soon, thanks.
Kind regards
(CID:129409615)
Jef Faridi Yeah, just share with me the box folder i will upload the latest backup file
Thanks for your support
Kind Regards
(CID:129409620)
Jef Faridi Good Morning
Ive shared the DB file on Dropbox you can investigate
Thanks and regards
(CID:129411554)
Hi Waseem,
Many thanks - I will get back to you as soon as possible.
Kind regards
(CID:129411607)
Any update ?
(CID:129412102)
Hi Waseem,
Currently looking into this and will get back to you asap, thanks.
Kind regards
(CID:129412120)
Hi Waseem,
We have located cause/issue with couple of devices in the setup, so I will send you instructions to resolve the issue. I will send you a direct email shortly, thanks.
Kind regards
(CID:129412931)
Posted: 2020-07-04 03:31 PM . Last Modified: 2023-10-22 04:09 AM
