Posted: 2020-07-04 07:20 PM . Last Modified: 2024-04-04 11:15 PM
Unable to map device sensors in dco from modbus strio devices of dce
(CID:132654774)
I have created the virtual sensor from the temperature value available in modbus pdu connectect. I have associated the temperature value available to the temperature device available in the genoma but I cannot map it or use it into the cooling 3D simulation
(CID:132654874)
Hi Giovanni,
Virtual sensors created in DCE are not designed to be used outside the DCE itself, they do not meet the DCO device/sensors requirements. So associating the virtual temperature sensors in DCO will not bring you any temperature data (to DCO).
Kind regards
(CID:132654882)
Posted: 2020-07-04 07:20 PM . Last Modified: 2023-10-22 04:09 AM
