UCS Manager integration in DCO - UCS blade power information not shown
  • UCS Manager integration in DCO - UCS blade power information not shown
127
65
Posted: ‎2020-07-03 05:01 AM . Last Modified: ‎2024-04-08 11:29 PM
1027
DCO 7.5 SP4 has been integrated with UCS Manager. The problem is that some of the blades are showing proper realtime power information while others not. What is the reason behind that?
Note: of course both servers are powered on and monitored more than one week.
(CID:106892528)
  • Data Center Operation
Replies 7
Posted: ‎2020-07-03 05:01 AM . Last Modified: ‎2024-04-08 11:28 PM
Hi Mate Fekete, thanks for posting! Let's see who can be of assistance here. @community - anyone know the reason for this? Best, Stine
(CID:106892700)
Hi Mate, Would it be possible to ask for the server & client logs? I will send you an invite to my =S= box, just in case if you would share the files directly with me, thanks. Kind regards
(CID:107448659)
Hi Jef, Logs have been uploaded. Thank you.
(CID:108234495)
1027
Hi Mate,
Many thanks for the providing the data, the log files complaining about the connection to Cisco UCS manager, saying "Cold not login: Authentication failed ".  So basically the user name or password (for the integration) might be incorrect.  You might want to verify the credentials and possibly use the "Test" bottom  that is described here: Configuring Cisco UCS Manager Integration, to test the connection.
Kind regards
(CID:108234580)
Hi Mate
The second screen shot is how it looks in my test environment when the blade reports power used = 0w and adjusted name plate on the blade is set to 0w.
Could that be the case in your scenario too?
Ulrik
(CID:123346740)
Posted: ‎2020-07-03 05:02 AM . Last Modified: ‎2024-04-08 11:28 PM
Hi Ulrik,
Yes, I checked this is the case. To which value should I change?
Mate
(CID:123346768)
Posted: ‎2020-07-03 05:02 AM . Last Modified: ‎2023-10-31 11:39 PM
