Posted: 2022-04-27 03:12 AM
I asked the person in charge of the DCO software to add U-Height.
He did that, but I can not see that value when I access the API.
Can U-Height be available through the API? how?
Thanks.
Posted: 2022-04-27 05:05 AM
'/assets/search' would not return the info you need, you would need to use GET /assets/{asset-id}
please see my illustration above.
Kind regards,
Posted: 2022-04-27 03:59 AM
Hello, which version of DCO are you using?
I believe the below highlighted item is the U-height of the server I queried via the DCO rest api (DCO 8.3.2 or newer).
Posted: 2022-04-27 04:38 AM
Sorry, looks like the picture I shared did not paste properly. I re-added the screenshot.
This value is present in both DCO and ITA and appears to represent U-Height of the device.
Posted: 2022-04-27 04:50 AM . Last Modified: 2022-04-27 05:14 AM
Hi Shlomit,
Yes, it is possible to get the assets/device 'Unit height' value via the REST api. ( https://<ITA server IP>api/current/docs/index.html )
Here is an illustration:
a device with Unit height 2
go to https://<ITA server IP>api/current/docs/index.html
enter your asset-id
and then hit the 'Try it out!'
in the Response Body window, device 'unitHeight' should be displayed:
Kind regards,
Posted: 2022-04-27 04:56 AM
I go to https://.../api/v8.1/assets/search, no height, I get only the attributes:
"id": "",
"type": "",
"location": " ",
"parentId": "",
"parentName": "",
"parentType": "",
"roomId": "",
"roomName": "",
"roomType": "",
"cageName": "",
"rackName": "",
"barcode": "",
"description": "",
"name": "",
"manufacturer": "",
"modelName": "",
"partNumber": "",
"serialNumber": "",
"customPropertyKeys": "",
"customPropertyValues": "",
"luceneSearchScore":
Thanks a lot.
Kind regards,
