Trying to install StruxureWare Data Center Operation on a server without a network connection?
  • Trying to install StruxureWare Data Center Operation on a server without a network connection?
129
72
Posted: ‎2020-07-02 06:51 AM . Last Modified: ‎2024-04-10 01:51 AM
718
I have no network connectivity in my data centre at present. I want to have StruxureWare Data Center Operation running before I install servers in my DC?
(CID:77299722)
  • Data Center Operation
By default the StruxureWare Data Center Operation server needs to get an IP addres assigned during installation. However it is possible to install DCO without network connectivity available.
The process contains of two steps: installation and post-installation configuration (during which the network properties are configured)
You will need to connect a keyboard and a monitor to the server in order to perform the steps below.
Installation without network connection
The default installation searches for a DHCP server. Since t...
Configuration of network properties
You must configure at least one network port to connect to the s...
Putty or a similar tool to connect to the server (logon as root, using the IP address you entered above).
Edit the interfaces file:
# nano /etc/network/interfaces
Static IP address
auto lo
iface lo inet ...
Dynamic IP address
auto lo
iface lo in...
Restarting the network interfaces
For the changes to take place, you will need to restart the networ...
Reconfigure Operations
Next, the Operations service needs to be reconfigured:
this guide.
(CID:77299738)
Posted: ‎2020-07-02 06:51 AM . Last Modified: ‎2023-10-31 11:39 PM
