Threshold template
  • EcoStruxure IT forum
  • Threshold template
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 07:36 AM . Last Modified: ‎2024-04-08 04:08 AM
819
Threshold template
Is it possible to create a threshold template in DCE so it can be applied to new discovered device?
ST
(CID:110004108)
819
Hi Sandeep,
No, there is no way to create a threshold template. That was something that was considered some time ago but I believe there was not enough interest in it. I will add this post as a comment to the enhancement request but I do not think it is something that is going to happen, at least not in the near future.
Steve.
(CID:110004118)
Replies 4
820
Hi Sandeep,
Steve.
(CID:110004118)
On a side note, if it is an APC device and a threshold that can be set on the device itself, such a template can be created under the APC SNMP configuration option in DCE.
(CID:110004119)
Thanks Steven !
(CID:110004129)
Posted: ‎2020-07-03 07:36 AM . Last Modified: ‎2023-10-22 04:07 AM
