The web console just spins and says loading
Showing results forΒ
Did you mean:Β
  • The web console just spins and says loading
129
72
Posted: β€Ž2020-07-06 12:37 AM . Last Modified: β€Ž2024-04-02 11:30 PM
1917
When accessing the web console, it says loading and has a spinning icon. It never progresses past that screen. Any ideas on how to resolve.
(CID:153551392)
Posted: β€Ž2020-07-06 12:38 AM . Last Modified: β€Ž2024-04-02 11:29 PM
1917
Just rebooted the server, that resolved the issue.
(CID:153551785)
Replies 16
is this before or after you enter your login information?
(CID:153551402)
Before. This happens as soon as I enter the page.
(CID:153551405)
Have you looked to see if another window appears behind this screen with a login screen? I've noticed my login window is hidden behind this one.
(CID:153551407)
I'm not able to see a login box behind the loading. (screenshot attached).
(CID:153551418)
Posted: β€Ž2020-07-06 12:37 AM . Last Modified: β€Ž2024-04-02 11:29 PM
Alt-Tab look at the other windows you have.
(CID:153551423)
No other windows, I've tried it in other browsers. Here is a screenshot from Internet Explorer.
(CID:153551427)
i think a laptop/pc reboot may be in order. It has something to do with the login, i wonder if a pop-up blocker has blocked the login window.
(CID:153551430)
(CID:153551437)
Just completed a reboot and still not receiving a pop up for login.
(CID:153551446)
You have logged into this web console before? Do you have client level access?
(CID:153551448)
I switched to the console to verify that I could login to it but it seems to be stopped at Loading device groups.
(CID:153551453)
You may have a server ram/memory issue.
(CID:153551458)
1918
(CID:153551785)
Dear Dustin Ward,
Then convert your comment into answer and mark it as resolved πŸ˜€.
With respect.
(CID:153551789)
That will resolve the issue short term, but i would suggest researching your current memory utilization.
Thank you
(CID:153551856)
Posted: β€Ž2020-07-06 12:38 AM . Last Modified: β€Ž2023-10-22 04:06 AM
