Posted: 2020-07-02 09:42 AM . Last Modified: 2024-04-10 01:08 AM
How do I change temperature sensor value to Degree Celsius in DCO. Currently it is showing Fahrenheit. The temp/humidity sensor is directly connected to RPDU.
(CID:93193758)
Hi Shemilusman,
The temperature can be changed by the settings for the client.
It is found in the menu item "preferences->General" where you should chose "Metric" as system of measurement.
(CID:93193817)
Hi Shemilusman,
(CID:93193817)
Posted: 2020-07-02 09:42 AM . Last Modified: 2023-10-31 11:38 PM
