TH sensor Wrong Image
  • TH sensor Wrong Image
129
72
Posted: ‎2020-07-02 12:42 PM . Last Modified: ‎2024-04-09 11:45 PM
1134
    please see the attached picture, why TH sensor showing wrong image like RPDU in DCO 7.4.5.
(CID:96764653)
  • Data Center Operation
1135
Hi Ali,
Currently TH sensor expansion modules are represented wrongly.
The only way to tell the difference is by looking at the color where PDUs are colored green and environmental devices are colored yellow.
This is a known issue in the application which  is tracked to be solved in a later version of the software.
(CID:96764764)
Replies 5
Hi Ali, welcome to the community and thanks for posting! @community - any piece of advice?
(CID:96764744)
Hi Ali, What device do you have in the rack? The picture unfortunately doesn't show the model name. The APC Temperature & Humidity Sensor (AP9335TH) is in the genome catalog, but this device can not be front or rear mounted. If you use a Netbotz 200 will you get a device with a smaller depth. So you could consider replacing your device with the NB 200 and just rename it correct. Thanks Jesper
(CID:96764757)
1136
Hi Ali,
(CID:96764764)
Thanks Soren
(CID:96764950)
Posted: ‎2020-07-02 12:42 PM . Last Modified: ‎2023-10-31 11:39 PM
