Posted: 2020-07-03 02:41 PM . Last Modified: 2024-04-08 01:14 AM
Hi
We are using DCE 7.4.1 and today our security team come up with a security issue as after scan they come up with a result that
SMB is disabled , how can I enable to SMB feature in our DCIM
Kindly help me to solve this issue.
Regards
Seref
(CID:116362260)
Hi seref ertekin,
Unfortunately, I can't understand your question ☹️.
...and today our security team come up with a security issue as after scan they come up with a result that SMB is disabled...
I.e., you security team found, that on the DCE server the SMB-protocol (MS Windows File and printer sharing) as service is disabled? I correctly have understood you? But then it is not a problem or issue, and on the contrary security improvement.
...how can I enable to SMB feature in our DCIM
If theoretically (practically it is impossible) we enable this sharing protocol as service on the DCE server, then on the contrary you really will have problems with a security 😀.
Glad to help you.
(CID:116362281)
Posted: 2020-07-03 02:41 PM . Last Modified: 2024-04-08 01:13 AM
is DCE using SMB Version 1? Our systems are all patched now to block this? Could this be why out backups no longer work? Failed to mount windows share? All basic troubleshooting has been done. service account checked, paths checked, LUNS connected and can be accessed by service account etc?
(CID:122685690)
Posted: 2020-07-03 02:41 PM . Last Modified: 2023-10-22 04:03 AM
