Struxureware Portal stuck
  • EcoStruxure IT forum
  • Struxureware Portal stuck
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 03:03 PM . Last Modified: ‎2024-04-09 03:59 AM
665
I have been getting this screen at Portal each time I log in I can't understand where is the issue ? I have the latest Jre installed.
(CID:100340623)
  • Portal
Hi Soren, I think I got the answer...The issue was the Java Plugin. I had recently updated the JRE with the latest Java update 8 version 60. When I checked the system I found three different version of Java running which was confusing the whole stuff, so I removed all versions and all new updates and let the Portal installation manage it for me and the whole thing got sorted out.
(CID:100340728)
Hi Vineet, Could you elaborate on which portlets you see the error in? The error message is a generic error message used by Liferay that needs some more information to debug. Also if possible please provide the logs from the Portal server they are located in ..\StruxureWare Portal\tomcat-\logs /Søren
(CID:100340633)
(CID:100340728)
Posted: ‎2020-07-02 03:04 PM . Last Modified: ‎2023-10-31 11:37 PM
