Struxureware Portal&PME integration
  • Struxureware Portal&PME integration
126
65
Posted: ‎2020-07-03 01:07 AM . Last Modified: ‎2024-04-09 12:42 AM
1338
Hi Community,
Can anyone know how to integrate Sw Portal with PME using Ecostruxure Web Service?
Regards
Kerem
(CID:105468608)
  • Building Operations
  • Data Center Operation
  • Portal
  • power monitoring expert
Replies 4
1338
Hi Kerem,
Please follow configuration guide here
https://dcimsupport.apc.com/display/public/Portal/Configuring+StruxureWare+Portal
and you should be able to use PME portlets. Available data sources described here:
https://dcimsupport.apc.com/display/public/Portal/Portlet+data+sources
Hope it helps,
Ajay Nagar
(CID:105468622)
Posted: ‎2020-07-03 01:08 AM . Last Modified: ‎2024-04-09 12:42 AM
Thanks for answer Ajay, Theese document is very helpful, but as you know PME server is not standalone server like DCO or DCE. PME server has external DB. So when i write the IP adress on Portal connection box, it is not working.. Can you know any information about that? Regards Kerem
(CID:105468665)
Hi Karem, the PME Server should be serving EWS endpoint. The database can be hosted on same or external db host, but the server's IP is the one serving the web services. Unfortunately I do not have access to a SxW portal otherwise I can share screenshots of the configuration. Lasse Simonsen do you know of a portal I can configure?
(CID:105468668)
Posted: ‎2020-07-03 01:08 AM . Last Modified: ‎2023-10-31 11:37 PM
