Posted: 2020-07-02 05:46 PM . Last Modified: 2024-04-09 02:12 AM
Error message when I try to adjust power on DCE server using DCO, see message attached
Rgds
(CID:104175076)
Hi Fabio, Please sent us the server logs and the client logs for us to troubleshoot. The log files can be downloaded from webmin. Thanks Jesper
(CID:104175079)
Posted: 2020-07-02 05:47 PM . Last Modified: 2024-04-09 02:12 AM
Tks Jespers ... the logfile is attached. Fabio
logs-192_168_1_136_at_11-19-15.tar.gz
(CID:104175106)
Hi Fabio, I assume this is one of the exercises from the training. Which one of the exercise is it? I can see from the log that the migration also failed. Do you know if this also failed on the other server? I can try and see if I can reproduce it on one of my servers. Does it only fail when you are in the power setup view? What did you try to change? I couldn't find the client log please also sent that one. Thanks Jesper
(CID:104175108)
Hi Fabio,
I have been able to reproduce the problem. I will log an error towards engineering so this can be fixed in the future. Until then can you use another device and then rename it as a Data Center Expert server.
Jesper
(CID:104175136)
Posted: 2020-07-02 05:47 PM . Last Modified: 2023-10-31 11:36 PM
