Posted: 2020-07-02 06:54 AM . Last Modified: 2024-04-10 01:51 AM
I have just upgraded to Operation 7.2.5 and went to import an AutoCAD floorplan and keep getting the following error.
"Drawing contains unsupported elements"
Just wondering if anyone else has encountered the same error or could point me in the right direction to find out what element is not supported. A tip for the developers here would be to actually display the element that was the cause of the error as the log files are a nightmare to try and understand.
(CID:77299734)
It is possible to see which elements are not supported in your AutoCAD file. this can be done by hovering the warning icon in the import dialog. Also there has been updates to the import functionality along the way. This is done in order to have better more supported elements.
(CID:82640912)
Posted: 2020-07-02 06:54 AM . Last Modified: 2023-10-31 11:37 PM
