StruxureWare Server and Client Version Mismatch
Showing results forΒ
Did you mean:Β
  • StruxureWare Server and Client Version Mismatch
129
72
Posted: β€Ž2020-07-04 01:58 AM . Last Modified: β€Ž2024-04-05 03:58 AM
3029
Hi
I keep getting a mismatch when trying to run SWC client.
The server version is 7.0.0.284 and I have rebooted it a few times.
I have also downloaded the software client directly from the server VM on different Windows computers.
I have verified that the downloaded client version is also 7.0.0.284
I am not connected via VPN.
Can anyone help?
(CID:126177881)
  • bug
Posted: β€Ž2020-07-04 01:59 AM . Last Modified: β€Ž2024-04-05 03:58 AM
3027
Hi Steven Marchetti, Rana Ajmal, spezialist
I've got this resolved now. Turned out to be an SSL issue.
Thanks πŸ˜€
(CID:128065222)
Replies 14
3027
Hi Seun,
As noted in k-base FA158446, the version is the main issue but it has also been seen when using VPN and hostname (not FQDN). Have you tried by IP? Have you tried connecting from other systems?
Is your login using a local account or active directory/LDAP account? If so, it could be that DCE is not capable of reaching the remote authentication server. I know this latter issue is an incorrect error but I believe it may have been updated to show the correct error in newer versions.
Steve
(CID:126177888)
Hi Steve,
Thanks for your response. I am not using VPN however.
Also, I am not using hostname nor FQDN, but connecting via IP.
The login is via local account.
(CID:126178039)
Hi Seun,
did you try from another client? Have you tried Rana Ajmal s suggestion about the full uninstall?  What os are you running. Since this is 7.0 it has been running for some time. Is it a VM or hardware server? What, if anything, has changed? Do you have any backups?
Steve.
(CID:126178067)
Hi Steve,
  • Tried on 3x different clients (Windows 7 and 10 Pro)
  • I have done a full uninstall as per Rana Ajmals advice
  • Server is on a VM
  • The only thing that has changed was an upgrade. The previous server version was 6.x.x. This was upgraded to 7.0.0.284 and since then, there has been the server/client mismatch
(CID:126178925)
Hi Seun,
Do you have a backup of the 6.x system. Your best option to return to a working version would likely be to restore to the 6.x version and try the upgrade again.
As for version info, I believe 7.0 was the first available as a VM. If that is the case, then the system is either a hardware server or the upgrade was done in a hardware server then a backup brought over to a VM.
Steve.
(CID:126179507)
3027
Hi seun.feyisetan,
            kindly follow the below steps.
1) uninstall the previous SWC clients including current version.
2) Delete the ISXC folder from C drive  (C:\Users\user-name\.isxc)
3) Download and install new client from IP.
BR,
Rana Ajmal
(CID:126177995)
Hi Rana Ajmal,
Thanks for your response and the suggestion.
I have not yet tried this...plus, I am not back in the office / internal network until Monday. I would not want to go via VPN as that has its potential issues (k-base FA158446) as highlighted by Steven Marchetti.
So, will give this a shot on Monday when I can connect via local IP...fingers crossed.
(CID:126178040)
Dear seun.feyisetan,
Have you solved your issue or not?
With respect.
(CID:126183368)
Hi spezialist, Not yet. I have raised it with APC and it seems the only thing to do now is to re-deploy the SWC server, which I want to do as a last resort. Have you got any ideas I can try before that please?
(CID:126183402)
Unfortunately, I do not have any new ideas on this. I think Steven Marchetti recommendations for you are the most correct, i.e.:
...Your best option to return to a working version would likely be to restore to the 6.x version and try the upgrade again.
Most recently, the customer also had a problem with the old ISX Central server, which for some reason could not be updated (Update ISX Central 6.3.0 -> 7.0.0: nothing to update?). And the solution to this problem is similar, i.e. re-deploy the ISX Central server. This is a guaranteed solution to the problem.
Many thanks for the feedback.
With respect.
(CID:126183498)
Thanks spezialist, Rana Ajmal and Steven Marchetti.
I think there is a backup of the 6.x.x system. I'll attempt the restore and upgrade again.
(CID:126184143)
3028
Thanks πŸ˜€
(CID:128065222)
I.e., the above problem only occurred when the DCE-client was connecting via the HTTPS protocol?
I understand you correctly?
Many thanks for the feedback πŸ˜€.
(CID:128065246)
Posted: β€Ž2020-07-04 02:00 AM . Last Modified: β€Ž2023-10-22 04:02 AM
