StruxureWare Portal not connecting to DCE
  • EcoStruxure IT forum
  • StruxureWare Portal not connecting to DCE
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 11:59 PM . Last Modified: ‎2024-04-02 11:44 PM
2087
Hi Team,
I just installed StuxureWare Portal on windows server, made sure I can access DCE on the same server via browser.
I also removed the demo and added both IP address for DCE and DCO.
However when I add a portlets I seem to be getting this error
What could I be missing.
Thanks.
(CID:152081165)
  • Portal
Replies 5
Hello Mashwiz
Would you be able to provide a screenshot of the portal control panel view displaying the configuration for the DCE server?
Regards
Greg Sterling
(CID:152081251)
(CID:152567861)
After unchecking the "demo mode" button did you click the "save demo" button just below it?
Does your DCE allow connections on port 80? If not, can you change the URL for the DCE connection in the above settings view to https://10.200.208.185, then save the setting and recheck the portlet preferences?
Regards
Greg Sterling
(CID:152568030)
Posted: ‎2020-07-06 12:00 AM . Last Modified: ‎2024-04-02 11:44 PM
Hi Greg,
Thank you, let me check and revert.
Regards
(CID:152568108)
Posted: ‎2020-07-06 12:00 AM . Last Modified: ‎2023-10-22 04:02 AM
