StruxureWare Data Center Expert
  • StruxureWare Data Center Expert
129
72
Posted: ‎2020-07-03 02:39 PM . Last Modified: ‎2024-04-08 01:14 AM
1265
Hi
We are currently working on a specification for installing StruxureWare Data Center Expert.
Is it possible to run Version 7.4.1 on a Windows 2012 R2 server?
The manual only states Windows 2003 (SP2).
Do any of the latest versions of Data Centre Expert, have the capability of running on Server 2012.
G
(CID:116361921)
  • DCIM Support
1265
Geoffrey,
StruxureWare Data Center Expert is only available as an OVA file (virtual machine) and on an appliance purchased from Schneider Electric.  Both of these options should be treated as an appliance, meaning that only limited access to the operating system is provided.
The references you are most likely talking about is in regards to the client software, which is used to access the Data Center Expert installation.  StruxureWare Data Center Expert works on a Server-Client architecture and communication between the two uses HTTP and/or HTTPS.
Cory
(CID:116361925)
Hi Corey
Thank you for the reply.
I understand now.
G
(CID:116361957)
Posted: ‎2020-07-03 02:39 PM . Last Modified: ‎2023-10-22 04:01 AM
