StruxureOn Local Configuration
  • EcoStruxure IT forum
  • StruxureOn Local Configuration
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 10:30 PM . Last Modified: ‎2024-04-07 11:03 PM
1061
Guys can we install StruxureOn and connected to the apps directly instead of going to APC cloud
also If I have migrate my 1U DCE Appliance to VM Appliance can we install StruxureOn on the same server
(CID:124522567)
  • Asset Advisor
Replies 6
1060
Hi Musllam.Binhalabi,
As far as I know this is impossible, because the central element of the StruxureOn digital service is Schneider Electric clouds (this is the main idea).
This is not necessary, since the latest version of DCE-7.4.3 natively supports the StruxureOn digital service.
If you want to install StruxureOn GW, then it should be a separate VM based on MS Windows Server.
Always glad to answer your questions.
(CID:124522767)
Ok now I get it.
DCE 7.4.X Appliance is capturing DC elements and it has built in StruxureOn service so all we have to do is enable StruxureOn accordingly all DCE data will be send to APC Cloud\Mobile App
(CID:124523340)
Yes that's right. If there are more questions, please ask.
(CID:124523344)
Have you solved this problem or not?
With respect.
(CID:125208269)
Hi spezialist
I have got replay from Schneider Team
Musllam
(CID:125211399)
Posted: ‎2020-07-03 10:31 PM . Last Modified: ‎2023-10-22 03:59 AM
