Smart-UPS X 750 Power Path
  • EcoStruxure IT forum
  • Smart-UPS X 750 Power Path
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:23 PM . Last Modified: ‎2024-04-03 03:01 AM
915
Hi there. In DCO is it possible to setup an rack-mounted APC Smart-UPS X 750 with a power path and devices connected to it. I would also want to associate it to its corresponding device in DCE. The current Smart-UPS X 750 Genomes in DCO don't appear to have a power option. Thanks - Warren.
(CID:141266947)
  • Data Center Operation
Replies 5
915
Hi Warren,
Currently modelling rack-mounted UPS (concerning the power path) in DCO is not supported. As a sort of work-around we might use/customize a floor standing UPS unit, resize it and place it near the rack.
Kind regards
(CID:141267292)
Thanks Jef - I will add it as feature request. Cheers.
(CID:141267405)
Posted: ‎2020-07-05 06:23 PM . Last Modified: ‎2024-04-03 03:00 AM
Hi Jef - I tried to do this using a generic single phase UPS and PDU. The only issue is that I cannot associate the Smart UPS 750 to the UPS or PDU for monitoring purposes. Do you have any Genome suggestions that may work?
(CID:141268043)
Hi Warren,
I could find a similar Smart UPS 750 in our data center (monitored by DCE) and could easily associate it to a UPS or PDU model in DCO:
Are you getting error messages?
Perhaps (only guessing) might be caused by some "old" data in client temp folder. So you might want to try: close the client, and then rename the following folder: C:\Users\\.isxo\8.2.12* (to 8.2.12_old). And start the client, (then the client temp files will be updated), see if that helps?
Otherwise I would need to ask for more details, thanks.
Kind regards
(CID:141268287)
Posted: ‎2020-07-05 06:23 PM . Last Modified: ‎2023-10-22 03:56 AM
