Simulated Impact of Cooling Failure - Temperature calculations
  • Simulated Impact of Cooling Failure - Temperature calculations
129
72
Posted: ‎2020-07-04 03:43 AM . Last Modified: ‎2024-04-05 03:13 AM
1206
A few days ago a client asked me where the temperature measurements were taken in the simulation of impacts.
I could not give a certain answer
More specifically what I attach in the image
The documentation does not make this topic clear, could someone tell me what the calculations are?
(CID:128063115)
  • Data Center Operation
Posted: ‎2020-07-04 03:44 AM . Last Modified: ‎2024-04-05 03:13 AM
1206
Calculated T values are from Capture Index (CI)
Understanding Real-time Temperature Predictions
About Capture Index prediction models
Capture Index itself is from write up in ASHRAE
J.W. VanGilder, S.K. Shrivastava, Capture Index: An Airflow-Based Rack Cooling Performance Metric, Published in ASHRAE Transactions 2007, Volume 113, Part 1.
How that exactly work, well that's a different question , I leave it to the community with more indepth mechanical/cooling knowledge 😀
(CID:128063354)
1207
(CID:128063354)
Thanks for the reply Christopherus, as expected, it is not something simple.
I will study the information to draw some conclusion.
And Thank you very much with ASHRAE reference
We hope if someone from the community contributes more information.
(CID:128063917)
Posted: ‎2020-07-04 03:44 AM . Last Modified: ‎2023-10-22 03:56 AM
