Shut off/Switch off fresh water valve through rope leak alarm
  • Shut off/Switch off fresh water valve through rope leak alarm
126
65
Posted: ‎2020-07-05 06:46 PM . Last Modified: ‎2024-04-03 02:53 AM
673
we are going to install the Rack monitor 450 and 550 at our client site .
Requirements:
We will connect the rope leak with rack monitor 550 or 450.
As Rope leak will generate the alarm, a shut of /Switch off command will be sent to fresh water valve.
Kindly, advise.
(CID:141272143)
Posted: ‎2020-07-05 06:46 PM . Last Modified: ‎2024-04-03 02:52 AM
Hi Shoaib,
Any sensor, including the leak rope sensor, is capable of triggering any alert action on the NetBotz appliance. If you're connected to an output relay or an outlet on the appliance, those can be configured to be triggered by the sensor. Assuming this is for emergency situations and not something that is expected on an hourly basis or something, it should work fine. I state this because for one thing, the leak rope takes a while to dry and it takes a while for the alarm to clear. If it was for something to be done on a regular basis instead of an alert situation, I'd recommend a float of some sort if possible to turn off the water.
Is there something more specific you're looking for?
Steve.
(CID:141272151)
Posted: ‎2020-07-05 06:46 PM . Last Modified: ‎2023-10-22 03:55 AM
