Severity transfer problem from DCE to DCO
  • Severity transfer problem from DCE to DCO
129
72
Posted: ‎2020-07-04 09:47 PM . Last Modified: ‎2024-04-04 03:33 AM
1350
Hello
We are using DCO 8.2.2 and DCE 7.5 .
I have problem that all critical severity alerts of the devices threshold transferred  in DCO like error . The warning severity - warning .
What I need to do for  the critical severity of DCE will appears in the DCO on severity critical too ?
(CID:133371928)
  • Data Center Operation
Replies 8
Posted: ‎2020-07-04 09:47 PM . Last Modified: ‎2024-04-04 03:32 AM
1350
Hi Boris,
I can confirm your observation, I'm also seeing this in my setup (DCO 8.2.7 and DCE 7.5).
I have registered a bug report for this, so the codes can be reviewed. Many thanks for reporting.
Kind regards
(CID:133372082)
Errors are not shown in DCO navigation ?
(CID:133374344)
Posted: ‎2020-07-04 09:48 PM . Last Modified: ‎2024-04-04 03:32 AM
Hi Milka,
Thanks for asking, but no, that's not the case. Basically the current issue is: alarms with "Critical" severity displayed as "Error" in DCO.
Kind regards
(CID:133374389)
What is the current status with this problem I also bumped into? Has it been fixed in DCE 7.6 or DCO 8.2.12 (which one is the culprit?)?
(CID:137725844)
we didn't install DCE 7.6 and DCO 8.2.12
I not sure if we will go to this upgrade
(CID:137725846)
Hi Michael,
It is not resolved yet, similar issue in DCO 8.2.12. We have an open enhancement case for this at the moment, I can keep an eye on this and let you know when fixed, thanks.
Kind regards
(CID:137725850)
Update:
It seems this is working as designed for all DCO versions. Based on the code review, it appears DCO only has 3 status codes where DCE has a lot more, so basically we are mapping multiple status codes to one. In this case Critical is mapped to Error.
Kind regards
(CID:141264693)
Posted: ‎2020-07-04 09:48 PM . Last Modified: ‎2023-10-22 03:55 AM
