Setting up the ETL client environment and "Spoon Client Library"
  • Setting up the ETL client environment and "Spoon Client Library"
126
65
Posted: ‎2020-07-04 11:32 PM . Last Modified: ‎2024-04-04 02:31 AM
841
I cloud not find the documents to setup the environment to develop custom transformation.
I took the following steps. Is this the appropriate procedure?
  1. Download pdi-ce-****.zip from SourceForge and unzipped.(data-integration folder is created)
  2. Download "Spoon Client Library" from webmin page and found "lib and plugins folders" in it.
  3. Copy these "lib and plugins folders" into "data-integration folder".
By the way, I'm developing custom transformation, but I still cannot understand the purpose of "Spoon Client Library".
I also found the DCO related steps, such as "DCO Cage Input" in the "design view" of Spoon, but I cloud not find the information how to use them.
Could you kindly explain the purpose of introducing "Spoon Client Library"?
Akihiro Yamagami
(CID:134031147)
  • Data Center Operation
841
Hi Akihiro,
I must admit, I am unsure if we have any official documentation on how to interact with these custom steps.  However, I can give you a brief explanation.
In a few words:
The "Spoon Client Library" is a library, which exposes Pentaho Data Integration/Spoon/PDI transformation steps specific for Struxuware Data Center Operation (DCO), to the PDI client.
Some deeper insights:
The steps will give you, the designer of ETL integrations, a means to interact with the DCO server directly, utilising some of the functionality and computations, done internally in DCO.
By the nature of the transformation steps, they're "black box" steps, which doesn't give you any insight into their inner workings. They do connect to a counter part on the  DCO Server, which they'll be able to connect to. The data they're exposing can be found directly from the output of the standard export job.
When I am designing a ETL export integration, I've rarely used the steps my self (I can't think of when, if ever), I am instead usualy basing them on the output from the standard export job, whenever I need some of the data generated through these steps. I've found it easier to work with in a general context, than using the usage specific steps from the library. We do however provide you with the option to use the steps, if you'd prefer.
I hope this was the information you needed, otherwise I can try to find you some official documentation (if we have any) for you.
Best regards,
Benjamin
(CID:134031629)
842
Hi Akihiro,
In a few words:
Best regards,
Benjamin
(CID:134031629)
Thank you for your detail explanation. It's quite helpful to understand ETL.
I understand that the steps of "Spoon Client Library" are internally used for connecting DCO server and user don't need to care the steps in general.
I could already enough data in export database using standard export job, swoExportJob.
So, I will use this export job.
Best regards,
Akihiro Yamagami
(CID:134032985)
Posted: ‎2020-07-04 11:32 PM . Last Modified: ‎2023-10-22 03:55 AM
