Service not started in DCO
  • Service not started in DCO
129
72
Posted: ‎2020-07-02 05:07 PM . Last Modified: ‎2024-04-09 02:34 AM
833
God Day  my DCO server show a message service not started in the web browser and the webmin module show
Application Status Down
Database Status Running alone
Backup Status Not completed
Essential services are not running on this node. Please reboot the node and monitor the status page.
If the problem persists, contact support. (jboss)
(CID:103586537)
  • Data Center Operation
833
Hi Omar,
As you may have noticed already, the notification says that the essential services are not running and you need to reboot the server.
However, before rebooting the server, I would suggest to verify the local disc is not full (via Webmin, -> "System Information").
If the local disc is full, then basically you need to free some space:
a) move the "old backup files" (from /data/backup) to somewhere else (your laptop or network drive for safe keeping)
b) ssh log in to the server, and run the following command to clean up, and then reboot:
sudo su
service operations purge
reboot
It will take approximately 15-20 minuets until the server is ready to be used.
Hope this helps.
Kind regards
(CID:103586545)
Hello team I facing the same issue I have try the process sudo su service operations purge reboot the same the thing. You can find screen shot attach
(CID:105472083)
Posted: ‎2020-07-02 05:07 PM . Last Modified: ‎2023-10-31 11:35 PM
