Scan barcode always "flash back" in VIZOR by iPAD device
  • Scan barcode always "flash back" in VIZOR by iPAD device
127
65
Posted: ‎2020-07-03 04:06 AM . Last Modified: ‎2024-04-08 11:46 PM
1161
Hi Team ,
I just test the VIZOR for barcode function on iPAD device, I can scan the barcode before keyin in DCO and the
message form VIZOR show : "scanresult: Barcode xxxxxxxxxxxxxx not found" .
But when I keyin the barcode to the IT device in the DCO , then used iPAD login VIZOR to scan the barcode .
It's always flash back and no response .
I also used my moblie to test , sometime work and sometime didn't work .
Does anyone know this issue and what's the problem on it ? Your help would be appreciate .
My iPAD version : 7.1.1  ,  Type: MD330TA/A
Best Regards
(CID:106209254)
  • Data Center Operation
  • bug
Replies 11
Billy, perhaps get a video recording of the issue?that might help to explain to the team. Also, are you using DCO 750 or DCO 8?
(CID:106209265)
Hi Chris , Thank you for advise , due to the video is too large so that I put it into box. Below download link for all of your reference , kindly help on what's the problem , many thanks . BTW I'm using DCO 7.5 . https://schneider-electric.box.com/s/nz7l5akhj6t3u9zdbxcwtkezreh6x3h9 Best Regards
(CID:106209297)
Hello .. Does anyone could response this issue ? Many thanks . Best Regards
(CID:106209521)
Posted: ‎2020-07-03 04:06 AM . Last Modified: ‎2024-04-08 11:45 PM
Hello ..
Does anyone could help on this issue ?  Many thanks .
Best Regards
(CID:106209646)
1161
Hi Billy,
I'm not sure that this Bar Code Scanning feature has been tested from the software development point of view, but your test obviously shows that there might be some issues. So I will log a software enhancement case, thanks.
Kind regards
(CID:106209772)
Hi Jef , Thanks for help , due to we already put this feature in basic design for our customer , kindly help us to fix this issue , otherwise we will have problem for our project ,thank you . Best Regards
(CID:106209787)
Hi Chu Li, I was reviewing your shared video capture, and as a summary I've noticed the following steps: 1. scanresult returns "barcode xxx not found" 2. you've entered the barcode xxx to your DCO model and saved. 3. and then re-scanning (step 1) returns no result. I was wondering if restarting the VIZOR (between step 2 and step 3) would have helped? Kind regards
(CID:106209843)
Posted: ‎2020-07-03 04:07 AM . Last Modified: ‎2024-04-08 11:45 PM
Hi Jef , Yes ,I have test by your concern and also had the same issue , this info for your reference . Any info that I can provide ? Just let me know ,thank you so much . Best Regards
(CID:106209873)
Hi Chu Li, Many thanks, I will contact you (directly) for the customer name, so it can be added to the case, thanks. Kind regards
(CID:106209879)
By the way, you might want to check-out the DCO 8 Web Client https://dcimsupport.apc.com/display/UADCO8x/What+is+new+in+StruxureWare+Data+Center+Operation+8.0#Wh... that's a new feature shipped with DCO 8, I know it doesn't have barcode scanning capabilities, but it might be potentially a good replacement for VIZOR (or even Mobile). Kind regards
(CID:106210095)
Posted: ‎2020-07-03 04:07 AM . Last Modified: ‎2023-10-31 11:34 PM
