SW Portal Importing User can not Log In
  • SW Portal Importing User can not Log In
129
72
Posted: ‎2020-07-03 02:20 AM . Last Modified: ‎2024-04-09 12:19 AM
702
Hi All,
I have integrated Active Directory/LDAP to SW Portal and i have users as you can see attached image. Actually all user have  Owner permisions but, no users can log in the Portal own password. So what should i check for login for Active Directory user?
Best Regards
(CID:105474251)
  • Portal
Hi Kerem
If I understand your issue correctly, you are trying to login to SW Portal using domain username and password, in order to do so can you check in your LDAP Authentication configuration in SW Portal what did you set Authentication Search Filter to it should be set to cn=@screen_name@
regards
(CID:106202970)
Posted: ‎2020-07-03 02:20 AM . Last Modified: ‎2023-10-31 11:37 PM
