SSL y TLS Data Center Expert
  • EcoStruxure IT forum
  • SSL y TLS Data Center Expert
126
65
Back to EcoStruxure IT forum
JonathanCruz12
Crewman JonathanCruz12
Crewman
Posted: ‎2023-10-31 08:29 AM . Last Modified: ‎2023-10-31 08:31 AM
1453
How can I select which versions of the SSL and TLS protocol Data Center Expert can accept?
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2023-11-01 10:17 AM
I think this option was available until version 7.8.1...so after you don`t have this option
GraceSmith99
GraceSmith99
Cadet
Posted: ‎2024-02-22 10:37 PM
I think Schneider Electric's StruxureWare Data Center Expert (DCE) allows users to manage various settings, E.g. security protocols.
However, the ability to select specific SSL/TLS protocol versions can depend on the version of the software you are using and the basic operating system's capabilities.
Few steps you might follow to configure SSL/TLS settings in Data Center Expert:
First of all you need to open a web browser and navigate to the IP address or hostname of your Data Center Expert server. Now log in with your credentials.
Once logged in look for the 'System Menu' or 'System Settings' option. This is typically found in the top menu bar or within a settings or configuration section of the interface.
Now Within the system settings, one security options available. There might be a section specifically for network security or SSL/TLS settings.
After that you need to do the SSL/TLS Protocol Settings, If the software allows for customization of SSL/TLS protocols you should see options to enable or disable specific versions (e.g., TLS 1.0, TLS 1.1, TLS 1.2, TLS 1.3). It is generally recommended to disable older, less secure protocols like SSLv3 and enable the more secure TLS 1.2 and TLS 1.3. and If you want to know about the SSL/TLS protocol then refer this guide : https://www.ssl2buy.com/wiki/what-is-an-ssl-certificate#:~:text=in%20this%20article.-,SSL/TLS%20Prot...
After making your selections save the changes. You may need to restart the Data Center Expert services or the server itself for the changes to take effect.
If you do not find these options within the web client, it's possible that the version of Data Center Expert you are using does not support configurable SSL/TLS protocol selection through the UI.
In such cases, changes might need to be made directly on the server hosting Data Center Expert, which typically involves modifying configuration files or registry settings depending on whether the server is Linux or Windows-based.
