SSL Certificate for Devices
  • SSL Certificate for Devices
129
72
Posted: ‎2020-07-05 03:41 PM . Last Modified: ‎2024-04-03 11:20 PM
3386
Is there a command line utility to create Certificate Signing Requests and to push the cert to the devices? I have way too many to do manually using the Security Wizard.
Devices being: NMC 1 and NMC 2 Cards, Rack PDU's, InRows, etc.
Maybe this can be a feature added into DCE? *Hint Hint*
(CID:137727799)
  • security
Hi John Smith,
If you go to:
www.apc.com/tools/download
filter by software wizards
you'll see a file:
APC Network Management Card Security Wizard v1.0.4
You can use this or I believe next month some time there will be a command line utility available but that will only be for MC2 (AP9630/31/35), AOS v6.6.4 or higher.
AS for the feature request aspect, under the "Resources"–>"Feature Request" option in the above menu, you can suggest that directly to our engineers.
Steve
(CID:137727821)
Hi John Smith,
If you go to:
you'll see a file:
Steve
(CID:137727821)
Dear John Smith,
Please tell us if you could solve your question or not?
With respect.
(CID:137729830)
Posted: ‎2020-07-05 03:42 PM . Last Modified: ‎2023-10-22 03:50 AM
