Posted: 2020-07-03 01:48 PM . Last Modified: 2024-04-08 01:30 AM
How can I do to query information in the SQL database from another program?
(CID:113644415)
Hi Diego
You are not permitted to access the DCO internal DB.
But, you can export the data to another DB so you can write SQL to read it.
https://dcimsupport.apc.com/display/DCIMDEVELOPER/DCIM+Developer+Documentation
and
https://dcimsupport.apc.com/display/DCIMDEVELOPER/ETL+Export+Database
There are many of us on the forum who have a lot of experience with this environment so please ask your questions and share your experience here.
Cheers
Ed
(CID:113644468)
And a question on DCO or DCE? Judging by the tag - DCE.
(CID:113644504)
I have this video tutorial about accessing StruxureWare Data Centre Operation database:
External system integration through ETL
Note that the part about creating ETL databases is slightly outdated - this interface is moved to Webmin, but otherwise it is good.
(CID:113644734)
Hi Diego,
For DCE, you can't pull directly from the database but you can pull information from the server using the web API. INfo on this can be found here:
StruxureWare Data Center Expert Web Service API
Steve
(CID:113644929)
Posted: 2020-07-03 01:48 PM . Last Modified: 2023-10-22 03:49 AM
