SDMO generator connection difficulties
  • SDMO generator connection difficulties
129
72
Posted: ‎2020-07-04 04:07 AM . Last Modified: ‎2024-04-05 03:06 AM
1580
HI
someone has been able to connect a SDMO generator ( TELYS 1, RS485) to DCE, using the link 150 gateway. we have difficulties with the comunication between the generator and the gateway, someone has information on how to do it?
(CID:128066513)
1580
Dear Sergio,
Concerning the connection of the Schneider Electric EGX150 gateway, you can find good documentation on the official web-page https://www.schneider-electric.com/en/product/EGX150/link-150---ethernet-gateway---2-ethernetport---... (Product Datasheet and Instruction sheet).
And about the connection of the SDMO generator (genset control panel) you still, it is better to contact the vendor's service personnel of this generator. Or, first of all, you need to study the documentation for this SDMO generator (genset control panel) on how to connect it to external systems via the RS-485 bus.
I hope this helps you.
If you have any more questions, please ask.
(CID:128066718)
Replies 7
Dear Sergio,
20 Jun 2017 You already created an almost similar post . And I thought, that you could successfully solve your question.
I.e., you could not connect your SDMO generator to a DCE-server using the EGX150 gateway? Can you tell more about your problem in more detail?
With respect.
(CID:128066527)
1581
Dear Sergio,
(CID:128066718)
that is correct, but de firts question is about the posibility to do that. But now is about how can connect the SDMO TELYS 1 controler and the LINK 150 Gateway.if there are wiring diagrams, or a little more information on how to physically connect both devices.
Thanks in advance
(CID:128749415)
Posted: ‎2020-07-04 04:07 AM . Last Modified: ‎2024-04-05 03:05 AM
Hi
thanks for the help, we will try again with this new information, but it is difficult to find information about TELYS 1, it is an old controller. but thank you very much for your help anyway
Regards
(CID:128749404)
Ok, as soon as I have the necessary information about the old genset controller TELYS 1, I will publish it here.
If there are more questions, please ask.
(CID:128749413)
Hi, thank you so much
Regards
(CID:128749409)
Posted: ‎2020-07-04 04:07 AM . Last Modified: ‎2023-10-22 03:48 AM
