Rise DCO instalation log level
  • Rise DCO instalation log level
129
72
Posted: ‎2020-07-05 09:33 PM . Last Modified: ‎2024-04-03 12:46 AM
941
Hello
I have problem with installation DCO on Red Hat. The installation has been run correct and finished successfully, but DCO didn’t started . I installation log I doesn’t see any error .
In isxo.log files I see error regarding to DB , and it’s true DB didn’t create . In additionally the webmin has new GUI and the module of DCO not exists.
  1. Is there option run configuration/integration  script  separate (after installation ) ?
How I can rise the log level
(CID:147784788)
  • Data Center Operation
Replies 4
Hello
Is this very difficult question that any body can’t answer to me more 10 days
(CID:148343329)
942
Hi Boris,
Apparently the installation have not been successful. Usually unable to access the RHEL packages (during DCO installation) may result in unsuccessful installation. You might want to verify the prerequisites described in the following page:
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Installing+DCO+on+Red+Hat+Enterprise+Linux+7,
Kind regards
(CID:148343369)
Hello Jef
Unfortunately the installation of the DCO is finishing also success   .
When I start check I discovered that DB of DCO hasn’t created and dco didn’t start (I see according log files) .
My goal rise level of the installation log and get output why or what is reason the DB of DCO didn’t created ? for example .
I found a lot of problem for unsuccess installation although the install.log reported successful .
(CID:148344024)
Posted: ‎2020-07-05 09:34 PM . Last Modified: ‎2023-10-22 03:47 AM
