Request device support: big JVM error when attached DDF *.xml file
Showing results forΒ
Did you mean:Β
  • Request device support: big JVM error when attached DDF *.xml file
129
72
Posted: β€Ž2020-07-04 02:32 PM . Last Modified: β€Ž2024-04-05 02:36 AM
1405
Hi support,
Today I found the above problem. I.e., if in the form of a request for device support to attach for the validation of a DDF *.xml file, then after clicking on the REQUEST button, there is such a big JVM error:
If the DDF *.xml file is archived, for example in *.zip, then the device support request is generated normally.
Very thanks for the support.
(CID:128761299)
  • DCIM Support
  • bug
Posted: β€Ž2020-07-04 02:33 PM . Last Modified: β€Ž2024-04-05 02:35 AM
1404
Update: xml bug is now solved and patch is live and ready to be used πŸ˜€
(CID:128761368)
Replies 7
Hi spezialist, thanks for reporting πŸ˜€
We'll look into it.
Cheers,
Stine
(CID:128761311)
Posted: β€Ž2020-07-04 02:33 PM . Last Modified: β€Ž2024-04-05 02:36 AM
Ok, thanks for the feedback πŸ˜€.
(CID:128761321)
1405
Hello spezialist,
the backend server that hosts the requests cannot parse your xml, thus the error. I'll try find a solution to this within the week. Thanks for bringing this to our attention.
(CID:128761329)
(CID:128761335)
1405
(CID:128761368)
Ok, very thanks for the support πŸ˜€.
(CID:128761381)
Posted: β€Ž2020-07-04 02:33 PM . Last Modified: β€Ž2023-10-22 03:46 AM
