Remove old java version from Portal
  • Remove old java version from Portal
126
65
Posted: ‎2020-07-05 03:49 PM . Last Modified: ‎2024-04-03 11:18 PM
839
Hi All,
Can we remove old java version from old portal version installed? Old portal using Java 6 while latest version using Java 7
Best Regards,
Tj
(CID:137729226)
  • Portal
839
Hi TJ,
I don't think that would work. StruxureWare Portal is build on Liferay 6.1, which may work with its shipped Java.
As far as I know there are no plans at the moment to update Portal to the latest Liferay platform.
Kind regards
(CID:137729252)
Replies 4
840
Hi TJ,
Kind regards
(CID:137729252)
Jef,
Thanks for the prompt reply
BR,
TJ
(CID:137729792)
Hi TJ,
You are most welcome,
Kind regards
(CID:137730107)
Posted: ‎2020-07-05 03:50 PM . Last Modified: ‎2023-10-22 03:45 AM
