Posted: 2020-07-02 10:51 PM . Last Modified: 2024-04-09 01:19 AM
Hi Community,
Do you have instructions to reconfigure the DCO VM network settings from the VMware console view?
I presume it requires going into Recovery Mode during the server startup and entering Linux commands afterwards. But I just want to confirm this and what commands to use.
Thanks a lot!
(CID:105461762)
Hi John,
This can be done through Webmin to a point
Hope this helps
(CID:105461777)
Posted: 2020-07-02 10:51 PM . Last Modified: 2024-04-09 01:18 AM
Hi Hren, I did see that one already. That only works if you already know the existing IP address. The existing IP settings are unknown, so we need to know how to reconfigure it from the server back end. Thanks!
(CID:105461781)
Posted: 2020-07-02 10:52 PM . Last Modified: 2024-04-09 01:18 AM
The current IP address of the server can be found from the CLI of the server (monitor & keyboard attached) using the login specified during installation. The command to be used is sudo ifconfig and your password when prompted.
(CID:105461881)
Posted: 2020-07-02 10:52 PM . Last Modified: 2023-10-31 11:32 PM
