Posted: โ2020-07-03 03:34 PM . Last Modified: โ2024-04-08 12:55 AM
We have installed DCO 8.0.3 and I have problems communicating with HP Oneview 3.00.05-0271823, any idea why the external system returns an error?
(CID:116925747)
Hi Davis,
We have started Supporting HP OneView version 3.0 from DCO 8.1 release.
We support HP OneView version 2.0.2 for DCO 8.0.3 release.
Satish
(CID:116925813)
Hi Davis,
Satish
(CID:116925813)
I am running OneView 3.0 and DCO 8.1 and I am unable to get DCO to get a successful test connection.
I am using a local DCO account on OneView and I have tried both read only and infrastructure admin but it still get the error bellow which does not help me much identify what the problem is.
(CID:119048821)
(CID:119050363)
Posted: โ2020-07-03 03:35 PM . Last Modified: โ2024-04-08 12:55 AM
Using a domain account seems to test connection successfully (thanks) but now im getting this error "DCO Unexpected Error "javax.ejb"
Any thoughts?
(CID:119050757)
Hi Chad, you can disable the firewall in Webadmin and delete the certificate loaded from the OneView in the DCO.
(CID:120131818)
Thanks Davis, that seemed to resolve the issue ๐
(CID:126158796)
Posted: โ2020-07-03 03:35 PM . Last Modified: โ2023-10-22 03:39 AM
Youโve reached the end of your document
