Problem adding sensors to the map in DCE
  • Problem adding sensors to the map in DCE
129
72
Posted: ‎2020-07-06 01:24 AM . Last Modified: ‎2024-04-02 11:14 PM
1595
I have a problem with the configuration of the maps in DCE, I'm trying to add to the map sensors from devices that are below in the hierarchy, but only a limited number of devices appear in the 'add to map' search screen. The map is located at a point in the hierarchy while the devices are distributed in different folders below (they are children).
Thanks in advance
(CID:154796145)
  • bug
Posted: ‎2020-07-06 01:24 AM . Last Modified: ‎2023-10-22 03:38 AM
